ATC 70... No Spark
ATC 70... No Spark
I have a 1984 ATC 70. Hasn't been run in 3 or 4 years & my dad let it sit outside part of that time. I'm starting to restore it.
I'm not getting any spark. I've tried more than 1 brand new plug. I've stuck a screwdriver in the end if the plug wire & held on. Nothing.
I disconnected the ground wire of the ignition switch to make sure it wasn't grounded out.
Are the points my most likely problem? Are any special tools required to change them? Flywheel puller, etc?
Is there a "cost effective way to change over to a CDI ignition?
Thanks.
Thanks.
ATC 70... No Spark
They sell the CDI setup on Ebay for like $100 I hear it wakes the bike up and it runs a lot better. I would just put some points in it all you need is a fly wheel puller.
http://dratv.com/atelpar1.html
ATC 70... No Spark
You should make sure the bike is wired up right. You can get wiring diagrams from www.3wheelerworld.com. If you look and the wires are done right, then it may be problems with the CDI, or spark advancer or some component like that, however I don't think its common for parts like that to just give out, unless tampered with. I think you should check the wiring over.
fordfaithful21
12-07-2015 05:52 PM
Cdenton
Technical and How-To Articles
09-09-2015 11:23 AM
