ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   ATC 3-Wheelers (https://atvconnection.com/forums/atc-3-wheelers/)
-   -   84 200S that's working great (https://atvconnection.com/forums/atc-3-wheelers/299898-84-200s-thats-working-great.html)
rjdad Oct 22, 2008 12:00 PM
I have a 84 200S that runs great. When I change the oil it comes out black and I was wondering if there is some type of flush that I can use that will remove the excess carbon and not damage the clutch system. Thanks as always.
2XVision Oct 22, 2008 06:10 PM
While it`s true some trash builds up in the crankcase due to clutch wear and etc. I`ve found it in several I`ve torn down. I would drain some oil out maybe a quarter way down, pour in some seafoam to the full mark. Then ride but not hard for about 15 minutes. Then change the oil. You`ll be surprised how black the oil is that comes out, also make sure you tilt it and let it drain at least 30 minutes. On the refill I recommend pure synthetic oil. As in most cases using regular conventional oil after as little as 2 hours of riding it`ll already be black. After switching to synthetic I can get 10 to 12 hours before the oil goes black.
SMFREY Oct 25, 2008 12:51 AM
I am not so sure putting synthetic oil in an older engine with automatic clutch would a good move
On these engines I have found the Honda Gen 4 oil works great
I run in all my bikes
What I did was simply change oil a couple times after each weekend riding
Now when I change oil it comes out clean
Just my opinion
Stay Safe
Ray
© 2026 MH Sub I, LLC dba Internet Brands
