GOKI Starter Kit for atc 200
I have been looking for a starter kit for a atc 200 and i found a kit. It is made by GOKI and they have a kit for a atc 185 and 200 and another kit for a atc 200s. I was wondering what the diffrences are or if there is even a diffrence. I need a eletric start kit for my three wheeler because of the 12:1 compression. The recoils are breaking and i am on my second one.
if i'm not mistaken the 200's have a compression relief cable? is yours on it?
yes it has a cable on it. But it is a diffrent engine from a atc 200s put on a atc 200. i belive it is a 82
The Goki 200 185 and 200s kit are all teh same. I had one on my 200s and now tis on my 200. Your going to want to get the decompression working. You can still order the decompresion lever for the atc200/185 which is the same for the 200e and 200es, looks morefunctionally pleasing. The electric start kit goes on quick and easy. Like 2 hour project. It wont crank it overif you start on a compressions troke, so yould still want to slowly pull the motor over by hand to get past the compression then hit the starter, or you'd want to make sure you decomp is working to get the crank spinning (same procedure with a stock starter on the big reds). Once its spinning it will crank the motor over like its going out of style. RTV silicone will be your friend to prevent water from entering in around the casting and starter motor.
The biggest drawback is they're friggin expensive new, like $350 for the kit. |
Do you think it could turn it over since it has 12:1 compression
And about the price i found one for $275 |
Yes it will, but not without a functioning decompression system.
If you Don't flip the decompressor and just crank it on a compression stroke, it will stop dead in its tracks, same as everything else. |
Thanks for the help, i will probaly buy the kit in a day or so and in a week i will maby inform you how i did. I am currently in the process of painting the whole thing.
Hey, good news i got the kit put on and it works great. Now it is so much easyer to start. And even with the High compression it turns over really easy. I took of the pull start because i dont need it any more. I made a new cover out of thick sheet metal and it works great.
so what your saying is that it will work on any compression level
Yes it should work on any compression level.
