1981 atc 200 turbo
i am new to the site but i just got a 200 running and runs well but im looking for more speed i want to put a new lower end in it and rebuild the top end hopfully a bore and rings.
i want to put a t16 turbo from a eagle talon on it for ****s and giggles and suggestiion on what i can do to go faster |
IMO the 200cc wont have the power to spin the turbo effectively plus all the custom work needed to make it fit ... and with a model with no suspension ?? there are the basic things like piston, cam, exhaust, carb, and sprocket sizes you can try but if your looking for speed id look towards a 250r or a 200/350x
I have a 82 200 and i put hi-compression piston on it and put 1 tooth bigger on the front sprocket and it whent 60 and i am 300lb! You can make them get power really easy. I found a racing cam for it and plan on puting it on with new valve springs that are heavyer, that will have power then.
