need rims?dont know size
so i picked up a 185s last night that needs rear rims and tires. someone used 8x10 trailer tires. they welded in centers and drilled holes....so my ride looks and rides like crap.
i would like to get new rims and tires but they are 3 bolt? what gives... all of the rims i find are 4 bolt. do i need to change out the hubs to 4 bolt or can i find 3 bolt rims somewhere. anyone got a link where i can buy new ones or if anyone has a stock set for cheap that will bolt up let me know. i just want the rims so i can ride this thing.....ill buy new tires at walmart |
Check ebay first for the 3 lug wheels. If nothing, I would recommed switching overto 4 lugs, if it can be done for a reasonable price. basically all of the wheel aftermarket is devoted to 4
The problem with switching to 4 lug hubs is the old 3 wheelers have 25 spline axles and the newer 4 lug hubs are 24 spline to match the newer 24 spline axles. If I were you I would find a pair locally maybe craigslist or something or find a parts bike that you can try them first to make sure they fit the axle.
Hmm,I did not know that.. then yes find some 3 lug wheels locally or on ebay or something
Or just find 4 lug hubs from a atc 200. Same axle diffrent hub.
