which is faster 250sx, 200x?
Old 05-05-2002, 06:46 PM
EricT's Avatar
and what is the top speeds?
Old 05-05-2002, 06:57 PM
KNOWSALOT's Avatar
The Facility
I don't remember from then what the actual numbers were, but a 250SX and the '83-'85200X will be pretty close, but the 200X should edge it out.
The '86-'87200X will completly destroy the 250SX in top end speed.[and take off]
Old 05-05-2002, 07:52 PM
EricT's Avatar
how much horsepower does the 250sx have?
Old 05-07-2002, 08:34 PM
200XRYDER's Avatar
You really cant compare the two. Especially a 250SX to a 86/87 200x. the SX's were shaft driven, heavy, had electric start and an autoclutch and would do about 55 tops. The 200'x could do about 60-65 stock, 86/87's being totally differant and much much better machiens (I ahve an 87 that will do around 70 with my mods. A 250SX is a workers machine or for someone who'd work and want to playa roudn occassionally, they were very nice ATC's but nothing to a 86/87 X!!
Old 05-08-2002, 08:09 PM
4x4mudslinger's Avatar
Is there much difference between an 85' 200X and an 86'-87'?? I have an 85'.
Old 05-08-2002, 08:18 PM
200XRYDER's Avatar
Yes---Huuuge differances, internally and externally. They are 4 valve 199cc's compared to the 2 valve 192cc's in the 83-85 models for one large change. They also have a 6 speed tranmission. Theres a whole bunch of differances but those are two fo the most imnportant I suppose.
Rob
www.trikeriders.com <~~ go there if u liek trieks!
Old 05-19-2002, 10:52 PM
350rcherdude's Avatar
the 87 200x is not a 4 valve it is 2, the 350x is a 4 valve
Old 05-19-2002, 11:01 PM
200XRYDER's Avatar
wrong, 350.
83-85 200x=2 valve
86/87 200x= 4 valve
I would know, I own one and its common knowledge to begin with.
Rob
Old 05-19-2002, 11:04 PM
if it is 4 valve why is there only one exhasust pipe coming out of the head.
and i had mine appart and if you cared to look it is only 2 valve. son
Old 05-20-2002, 09:26 PM
250rampage's Avatar
The 300ex is a 4-valve head, and it only has one headpipe. How 'bout the CRF450 and YZ426, yep that's right, one headpipe.
Quick Reply: which is faster 250sx, 200x?
