Well I went through and replaced things (maintenance things) well I replaced the coil wire (it was a copper coil wire) with a silicone 7mm wire. Well now after every ride, it fries the wire (black on the inside about 1/8" in) WHY?? I threw away the old wire
Do I need to go with another copper wire OR a higher wire, 8mm? Dealer said it will be hard to match another wire. Ron |
