? for xc racers
i have a warrior and want to race it in xc and need to know if my set up is good for xc. i have on it whats in my sig and have front wheel spacers a standard wiseco piston/gasket set web cam mid range cam/ti vavle springs a barnett clutch kit. i will be getting works dual rate shocks and a durablue 2+2 axle a pair of hand guards and some rethal handle bars also maybe a new bumper. is this good enough to be competitive and is there any thing else that would benefit me enough that i cant be with out it. sorry if this was long but i need to know thanks for your replies
nurf bars and wider axles I seem to clip alot of trees and rocks, but thats just me. I did widen the front a little and it's about 1 1/2" wider than the rear. I use the XCT front tires at 23" and realy like this set up. For me being able to look at the wider front was better than just keep clipping everything. The front does slow me down some on the real tite stuff but has realy helped in conjunction with the tires to get over the rutted areas.
The best thing is to leave what you have and let your racing dictate your mods, after all it has to fit your riding style not ours.
Depending how your bottom end responds you may want to use the stock cam or do some gearing to over come the cam you have. Bottom and mid is the name of the game in my book, but thats me.
The best thing to do is,unless you have a real problem with your set up at this point, leave it alone. Nothings worse than spending money on a mod and then finding out during racing another mod would make it better than what you just did. So like I said before what ever you have run that and then let your racing dictate what you want/need next.
Best of luck to you.
i was planning on getting new 20in razr 2s when they come out anyway and if i have to go down on the gearing it would only be a few dollars but i know what u mean. i race then see what i need to change but i just wanted experienced racer opinions. oh and gaff do you actually race that lakota and what class do you race in. is a good quad because i was going to get a lakota but dealer talked me out of it
yup actually race it!
It is very quick in woods racing. Although it takes alot of money to get it going real good, just a pipe and jetting gets it going a hole lot better than stock.
I haven't woods raced it in a couple months, I've been hanging with my son at the mx track. So I have been mx racing it the last couple months. It's realy to heavy for mx but racing is to much in my blood to sit and watch. I've been holding my own so far but I also been racing open class, so it's tough to get a win. Although I've placed a few times.
In woods racing I do very well. I only been able to get in some open class races but now they have a sport class. The sport class is for 350cc and below, it includes the blaster also. Very good class but I probably won't get into any more woods racing untill my sons done with his season.
Where you live is the best hare scramble series. www.msws.org
09-30-2015 01:37 AM
MikeyBoyesq
08-10-2015 11:11 AM
