ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   ATV Videos (https://atvconnection.com/forums/atv-videos/)
-   -   HELP!!! Washed my atv and it won't start (https://atvconnection.com/forums/atv-videos/295801-help-washed-my-atv-wont-start.html)
G.A.S. Aug 15, 2008 06:06 PM
I rolled my 2008 sportsman 800 efi touring out of the garage. Sprayed it off with the power washer and rolled it back into the garage. A few hours later i went to start it and there was no power. I check the battery with a meter and it is puttin out over 12 volts. When I turn the key nothing happens. The instrument cluster does not come on. No 12 volts to the to anything. I checked all the fuses under storage compartment. They were all ok.
Any suggestions?? I need help
Thanks
MooseHenden Aug 18, 2008 04:59 PM
Check under the headlight pod for loose connections. There is a lot of electrical stuff in there.
MooseHenden Aug 18, 2008 05:26 PM
Hey, G.A.S. you should post this on the Polaris Forum. You'll get more and better answers than I can give you.
user493 Aug 19, 2008 04:10 AM
The owner's manual states that you should never use a power washer on your ATV. If you washed it with a bucket of soapy water and a garden hose like I do you wouldn't have any problems. Just something to keep in mind in the future.
teamhex Aug 20, 2008 07:02 PM
Really? I wash my Eiger with a power washer. Never had a problem. Maybe its because its a Polaris [img]i/expressions/face-icon-small-smile.gif[/img] jk guys.
user493 Aug 21, 2008 04:09 AM
Power washers can blow all the grease out of U-joints/CV joints and fill them with water, short out electrical connections, and take decals off. One of my friends blew the decals right off his Polaris at least 15 years ago and hasn't had any other problems with it. You just need to back off and take it easy.
BurtonIndie8 Aug 22, 2008 02:02 PM
if you just wash the body with a presure washer youll be fine just do wash any electrical or mechanical parts wiht it
user493 Aug 22, 2008 08:36 PM
<div class="FTQUOTE"><begin quote>Originally posted by: BurtonIndie8
if you just wash the body with a presure washer youll be fine just do wash any electrical or mechanical parts wiht it</end quote></div>
Like I said, my friend blew some decals right off of his.
sled05 Aug 22, 2008 09:52 PM
I have been washing my quads, two arctic cats, two Bombs, one Polaris, and my new Grizz with a 2500 psi power washer and have never had a problem. If you do every thing the manual says, you would bring it to the dealer to change the plug. Just use common sense and use a wide spray head and stay back about 24'. Did you check your kill switch
BurtonIndie8 Aug 23, 2008 01:58 AM
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
Like I said, my friend blew some decals right off of his.</end quote></div>
yea i blew a one off mine but it was just a little suzuki decal i didnt care that much
© 2026 MH Sub I, LLC dba Internet Brands
