Polaris 250 Trailblazer question
#16
Ok I got the quad. I have a few more questions.
Is there a fuse box on it somewhere? If so where? Because the lights dont work for some reason and I think maybe its a fuse?
The chain seems a bit loose, how should I tighten, just take a link out?
Where could I get an owners manual because it didnt come with one and I think it would answer a lot of my questions.
#18
Be sure to tighten the chain with load on the bike, if you tighten it unloaded the chain will be overtight when you get on it and you will be straining the chain, spockets and bearings. The fuses and the junction block I believe are in front of the fuel tank on the left side, should be able to remove a cover to access them.
#19
#20
Ok, ive looked all around this atv and I dont see where to change the oil at? Also will I just be changing oil or will I be chaning oil and filter? Ive tried so hard to get a manual and no response, called 2 polaris dealers who havent returned my calls and no response to emails. Also I noticed that the seat lifts up and i see something under there but i cant get the seat all the way up and dont want to risk breaking it so does anyone know the proper way to get the seat up?
