tire repair
tire repair
Get some soapy water (preferably in a spray bottle) spray tire until you see little bubbles forming where the air is leaking out of the tire. If you can't find any take tire off and try again. If you find a leak in the tire: go to your local hardware store and buy a tubeless tire repair kit, read directions then proceed. If the leak is at he bead (tire meets the rim): take it somewhere for them to check it out. You can also use stuff like fix-a-flat or green slime but I prefer not to use them so therefore I have no opinion on them.
