lt250r a good quad?
All the main wear items are readily available, yes. There are still quite a few of these kicking around and they have a good following. Oddly enough I think the fact that there are no new 2 stroke quads manufactured now has helped the old models out availability wise. I know I have no worries for finding parts for my Honda. I was able to get everything needed to rebuild a couple LT's a few years ago. Of course times change, eventually we may see a lot of YZ250 powered quads?
#15
There were just a few years of overlap with the Banshee and the Honda/Yamaha 450s. For the record, the 450 didn't kill the 2 stroke racers, as there is about a 12 year gap in production there. Heck, the dirtbikers can still buy new 2 strokes and they have had 4 stroke racers a lot longer.
#16
Older 2 stroke motors do not have as smooth and predictable of a powerband as 4 strokes do. A 4 stroke tends to accelerate smoothly with no surprises. The 2 stroke, on the other hand, will have an explosive burst of power, usually in the mid to upper powerband. Now there are some that have lethal low end power. From what I hear, the newer 2 stoke motors (modern 2 wheelers) have much smoother power delivery and some can even be lugged around whereas the older one did not like to lugged around. They are alot of fun to ride, but you do tend to shift gears more often.
#17
#18
Yes, they will wheelie just fine. Again, a lot depends on the power band characteristics of the motor, as a "pipey" delivery (bigger hit) tends to spin the rears more readily. It takes a bit more to master than a typical 4 stroke, but they have a good power to weight ratio. My brother used to ride wheelies on his '87 from one end of a field to the other.
#19
