Kymco 450i |
12-18-2017 06:37 PM |
Those were good old quads, not fast but reliable if taken care of. You need to do a lot more checking to see if it is a good buy or not. They always need a carb clean but just cleaning hardly ever works...what is needed is a complete carb rebuild with a good rebuild kit!! Valve adjustment is not bad if that is all it is??? Many things can cause valves to be out of adjustment, some are minor and some could be major, so a deeper investigation is needed. Run a compression check, check spark. check inside gas tank for any rust or crud. Check diffs for lube and or water and rust. Parts should be availiable but keep in mind Suzuki parts are expensive, more expensive than other mfgrs. Don't know why but this has been there biggest downfall over the years. They make good equipment but replacement parts are just plain expensive!
