ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   CAN-AM (BRP) (https://atvconnection.com/forums/can-am-brp/)
-   -   DS won't start in gear?? (https://atvconnection.com/forums/can-am-brp/103336-ds-wont-start-gear.html)
TyreSpinner Jun 9, 2003 04:39 PM
My DS will not start unless it's in neutral...Clutch fully pulled in. You just press the start button and nothing happens.
Is this normal?? Cuz i thought they were supposed to start in any gear...
Thanks
bombrider Jun 9, 2003 04:50 PM
Maybe the clutch springs? is your clutch sliping? could also be electrical i think.
just throwing some idea's...
TyreSpinner Jun 9, 2003 05:54 PM
I don't think it's slipping. But maybe it is and I don't know it.
Anyone else got suggestions??
hinglbyds Jun 9, 2003 06:11 PM
I'm not standing next to my DS, but I think there is a clutch switch on the handlebar. Check the wires to the switch and make sure they are pluged in. If so then check continuity of the switch, if is ok then you have a broken wire somewhere.
I hope this helps!
TyreSpinner Jun 9, 2003 06:26 PM
Hrm...Where exactly is that switch located??
I see wires (covered in rubber boot) coming out of the start/headlight/kill switch assembly?? Is it in there??
Those are the only wires on the clutch side of the handle-bar that I can see??
TyreSpinner Jun 9, 2003 06:32 PM
OBSESSED Jun 9, 2003 07:20 PM
Yea Bro, mine does say magura on it also.
Make sure you rock it back and fourth while the clutch is in to make sure it is completley free....Thats a curious glitch....
Good luck, keep us posted....
TyreSpinner Jun 9, 2003 08:13 PM
Cool, thanks obsessed for clearing that up.
Does somebody have an answer to my last post??
Thanks
hinglbyds Jun 9, 2003 10:01 PM
If you follow the clutch lever inboard to the clutch lever pivot.....Well, between the pivot and the handlebars is a 1/2" - 5/8" round rubber grommet with two wires covered in blackshrink tubing...
There it is, I think...
Take off the clutch lever and check to see if there is FOD in the switch assy. Clean it, check the connections and if it still dosn't work, follow the wires down to the plug under the cowl and do a continuity check....
I hope this fixes the problem for you....
Hightower Jun 9, 2003 10:02 PM
there is a switch on the clutch perch, with wires seperate from those that go into the light/kill/start assembly. the purpose of this switch is to make sure the clutch is in if you're not in neutral, or else it won't let you start the bike. its prolly either this switch, or the wiring for it, as hinglby mentioned.
© 2026 MH Sub I, LLC dba Internet Brands
