Can't rev past 5g's
When I get to about 5,000 rpms' my DS cuts out like it is hitting the rev limitor. Does this sound like I might have something in my carb causing this to happen???
Also what kind of fuel filter are you guys using??? Thanks!!! |
Can't rev past 5g's
i had this problem when my battery was completely dead. i had to push start it. runs fine at low rpm as soon as you get it to about 5000rpm it cuts out...
Rob |
Can't rev past 5g's
That is prolly carb related...I'm almost certain...
Are you 100% sure your TAch is not giving you a bad reading?? Has it always done this? |
Can't rev past 5g's
No, it was running fine all day. Started going through some massive whoops, brought the front end up and then it started happening...
Can't rev past 5g's
I smell float or diaphragm issue...
Time to get those hands dirty and check the float level with a ruler or clear tube....And inspect the diaphragm for tears or holes.. Make sure you have gas.. |
Can't rev past 5g's
Make sure you have gas.. Rob |
Can't rev past 5g's
Yes I do have gas...lol....
I just pulled the diaphram off and no wholes or anything there.... This is the first time messing with the carb. What kind of screws should I buy. I know I should get allen head screws, but help me out here. Also I tried to remove the 2 screws on the top of the carb. Damn one was already stripped a little bit...hmm... so I ended up stripping it all the way... I assume it is time to get the drill out??? The other one came off with now problem. I will be forever greatfull for all the help. Need to get this thing running before next weekend. Thanks!!! |
Can't rev past 5g's
either use a chisel to loosen the screw or try vice grips.
Seems like these bikes have even the smallest screw welded in. jbt |
Can't rev past 5g's
If you have side-access to the screw (unfamaliar with stock carb), just use some good pliers (Don't use needle-noses, use meatier with a good smooth grip (no big teeth) and that has good leverage,,,it should come off no problem)..
I replaced my stripped screws with Grade 5 Phillips bolts... Grade 5 is enough I'd say...My new ones won't sheer or strip at all (so far anyway)... Some use the heavy duty black allen-head screws... Those are very high grade and are indestructable...But if they go in cross-thread or something happens... The aluminum casting on the carb itself will strip or get damaged before the bolt...$$$$... That's why they come with such buttery bolts.. Jeff |
Can't rev past 5g's
Ok, I am really confused. I tore the carb apart hoping to find like a grain of sand or something in a jet or somewhere. NOTHING!!! So before I put everything back together, anybody else know what it could have been???
Thanks!!! |
| All times are GMT -5. The time now is 11:20 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
