how to jump
Old Mar 29, 2004 | 01:56 AM
slidesquad's Avatar
Default how to jump
can some one tell me the steps to jumping a dirt bike in detail or a quad in detail i dont know how to preload the suspention all i can do is go fast and hit it and pull up and get like 2 ft of air a guy next to me on the same jump was going slower and got like 15-20 ft what do i need to do this is for a dirtbike or a quad i have bothe and need to learn how to on both thanks for your info
Old Mar 29, 2004 | 10:47 AM
dsracer666's Avatar
Default how to jump
I'm a slow and bad typer so I send you to the right place
http://www.douggust.com/content/Race.../prof_gust.htm
Old Mar 29, 2004 | 10:49 AM
SANDMAN430's Avatar
Default how to jump
hit the power and pray[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 29, 2004 | 02:41 PM
powerstroke01's Avatar
Default how to jump
And HOLD ON!!!1!!111!!!
Old Mar 29, 2004 | 03:43 PM
slidesquad's Avatar
Default how to jump
thanks for the link but it didnt help me 2 much
how do you preload you suspention befor the jump?
Old Mar 29, 2004 | 04:13 PM
MudStud's Avatar
Default how to jump
Honestly,, jumping is easy!! all you have to do is gas and go..
Landing,, That is the hard part! Learn to land not jump [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 29, 2004 | 05:03 PM
dsracer666's Avatar
Default how to jump
You want to try to press down on the quad just prior to leaving the jump...you're trying to get the springs to bounce back just before the wheels leave the ground. Not too soon, not too late. It takes practice to get the feel of when it's right.
When you're just starting out with pre-load, keep it even from front to back. Later, there may be times when you want to preload the back more, or the front more. For example, when you going over a short double-jump, you may want to pre-load the back shock more so that the back end hops up higher than the front. This would put you at a down-ward angle to match the landing ramp. If you're going for a step-up double, you may want to pre-load the front more so that the front of the quad stays higher to match the upcoming plateau.
Getting the feel for this takes practice. In a controlled setting, try pre-loading different ways to learn how your quad responds. The most important thing is to keep the rubber side of the quad pointing down...
this is from that site. http://www.douggust.com/content/ask_menu_riding.htm
Old Mar 29, 2004 | 05:14 PM
slidesquad's Avatar
Default how to jump
hey thanks for the info would you happen to know one more thing the little screws on my front suspetion tops what do they do and how do you adjust it i know it dose somethin lol thanks for all the info
Old Mar 29, 2004 | 05:20 PM
dsracer666's Avatar
Default how to jump
not sure my old shocks don't have that but it sounds like a compression damping screw. one way should stiffen and the other should soften the shocks compression
Old Mar 29, 2004 | 05:31 PM
slidesquad's Avatar
Default how to jump
what way do you think it would stiffenit?
