Sprockets
What do u guys reccomend for gearing, im goin for more low end so whats the difference if i change the front or rear sprocket?
Sprockets
for 12.00 to 15.00 you can buy a sprocket that is one tooth under stock. 16 is stock if I remember right . So try a 15 . To get the same effect by changing the rear , it would cost you around 50.00 +/- and you would have to order a 44 tooth. Buying a larger rear sprocket would most likely not fit either due to the sprocket gaurd .
Youll notice a big difference. |
Sprockets
nick
Check out my pic page there is a gear ratio chart on it that might be handy |
Sprockets
is the stock setup 40/16?
yea thats a nice chart Blue |
