ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   CAN-AM (BRP) (https://atvconnection.com/forums/can-am-brp/)
-   -   Spark Plug - DR9EA - Who's running them? (https://atvconnection.com/forums/can-am-brp/185802-spark-plug-dr9ea-whos-running-them.html)
DuneMe Jan 3, 2005 01:34 AM
Are most higher compression guys running these plugs?
Any running DR10EA?
Stock is DR8EA.
My understanding is the DR9EA is a cooler plug so will have less of a tendancy to cause pre-detonation?
Thanks.
ANNIHILATER Jan 3, 2005 01:51 AM
I run the 9's but I want to run the 10s.
ds650ratrider Jan 3, 2005 01:52 AM
I'm running the DR9EA on a 11:1 piston. Never tried anything else, so I can't speak to the gains or losses.
NickDS650 Jan 3, 2005 01:54 AM
im runnin the iridium stockers, whats the benifts of 9's over 8's?
DuneMe Jan 3, 2005 01:57 AM
See above as to why you may want to run the cooler plug.
Compression creates heat. . . pre-detonation.
TheChosenOne Jan 3, 2005 02:08 AM
And thus if you are borderline on the compression octane idea, say runnin 11.5-1 on 93 octane, could you use a DR9EA or a DR10EA and get away with it? Or would it at least help reduce the chances of a boom?
Eaglecollector Jan 3, 2005 11:59 AM
I run the 9's and my heat is exactly at the turn on the ground strap[img]i/expressions/face-icon-small-happy.gif[/img] can't get any better than that
amd Jan 3, 2005 09:11 PM
I run 9's on the bottle. With the 8's I would melt a plug (only twice though). I could back the jetting down on the bottle and be fine, but what fun is that....lol
Oh and just fyi I have been running 28 n20 and 31 fuel, which is around a 30 shot on the stock piston. Everything has been good so far. Got about 20 lbs through it. [img]i/expressions/face-icon-small-happy.gif[/img]
© 2026 MH Sub I, LLC dba Internet Brands
