Need some help guys
Old 04-02-2005, 09:06 PM
lilnotts's Avatar
Default Need some help guys
Originally posted by: mystereid
I know in certain areas they change the gasoline seasonallly and mix in different amounts of alcohol. Could it be that your glowing is just that the fuel is different and maybe still continuing to burn alittle as it enters the header. I think alittle glowing on fourstrokes in dark conditions isn't too bad.
actually we were talking about htat today, as the gas he put in he bought up north while he was snowmobiling, we are going to try draining to tank and putting in fresh stuff and see if that helps
Old 04-04-2005, 12:27 AM
lilnotts's Avatar
well after we changed the o-rings in the intake, and put some normal 87 we bough today it wasn't as bad as before, about 1 1/2" out of the head, it runs great, doesn't backfire, nothing, i put a bag around the air filter to choke it out and the glowing got worse, it went out longer and bright, but he pulled his plugs earlier tonight(before i put the bag over the airfilter) and they looked like it was running pretty lean still even after we went bigger on the pilot, this is starting to really **** me off
Old 04-04-2005, 12:30 AM
thumper650's Avatar
i am had the same prob when i was in the snow but not at the dunes
bafisher1986
07-21-2015 04:12 PM
rcappie4
07-18-2015 07:51 AM
Robinhood
07-13-2015 09:13 PM
Edgeslade
Where to Ride
07-10-2015 05:08 PM
Quick Reply: Need some help guys
