Intake valve ?'s
Old 04-20-2005, 10:27 PM
jackass650's Avatar
Default Intake valve ?'s
well i have my kid helping me so it goes quick, yes if you cant shim the valves it is because the outer edges start to curl towards the piston, mine looked kinda like a coffee saucer, they call this tuliping it is from the edge of the valves getting hammered against the valve seats, i replaced mine cause the didnt seal anymore and i had my jugg of putting in a new piston, but yes sooner or later they will be tuliped so much they wont seal then they need to be replaced, but if you can grind your shims and get the clearance and it starts good maybe you can make it till winter before having to do it, when it wont start when it is cold out is a good sign your valves are not seating and out of adjustment
Scooter's Shop
23
10-22-2015 07:04 PM
wrencher82
09-30-2015 04:27 AM
Sassinm1
09-30-2015 04:23 AM
maveikfe
1) Engine problems..
09-24-2015 10:36 PM
Todd C Wadas
2) Chassis problems..
09-23-2015 11:31 PM
Quick Reply: Intake valve ?'s
