Axle nut overtight?
Axle nut overtight?
I have an '04 X with the aluminum swing arm. I changed the skid plate to the Armadillo. This meant loosening the axle nut and pushing the axle to the sprocket side. Long story short. I just used a piece of brass and a hammer to tighten the axle nut. Is it possible to overtighten it? It seemed to spin just fine. Just wanted to make sure I'm not hurting the bearings.
Axle nut overtight?
Just re-packed my bearings last weekend.
You are suppose to torque the nut with a special wrench (it only $20 from the dealer) to 90 foot pounds then back it off rotate the axle a few times then re-tourge it to 40-50 foot pound.
Then re-tighten the little locking bolt that goes threw the lock nut.
