efi install questions, need help fast
i am installing the kms efi. kelly is closed so i can not reach him untill tueday. hopefully someone can help. what goes to the the vaccum port on the fuel pressure regulator? what goes to the second port on the fuel cap? is that just a vent? please help
the fuel pressure regulator has the one port open to atmosphere, no need to connect any thing there.
The fuel cap has one vent to atmosphere and one for the return fuel line.
Let us know when you fire it up [img]i/expressions/face-icon-small-cool.gif[/img]
thanks for the reply. i will finish it tonight.one more question i had. the orange wire was supposed to hook to the green wire with the tracer on the coil. the wires on both my coils were black with a white tracer then a green and white wire runs to the tach. so i hooked to the coil wire. was this correct?
No,
the orange wire needs to soldered to one of the wires that comes from the trigger coil not the ignition coils. The wire is green/ white on one side of the quick disconnect and become black /yellow on the other side of the quick disconnect( main harness side)( forgive me if I mix up the colors I'n not home and doing this from memory) I had the orange running to the black/yellow( main harness side) on my bike. If your not sure what the trigger coil is, the wires come out of the right side magnito cover with the 3 yellow wires from the stator windings. So look for (I think it's grey colored ) quick release connector approximately under the back end of the fuel tank and solder the orange wire in there.
good luck
good luck
thanks majorecho. you saved me alot of trouble shooting. i need to pick your brain on a couple of other things. does this system have any type of memory?seems like anytime i shut the bike off then restart i am starting from scratch on the fuel map again. it will spit and sputter then after a minute or so it will run good again. overall impression is awesome. i havent hooked up to the computer yet ill wait and talk to kelly first.
