HELP--Bomb. RALLY acceleration problem
Old Sep 14, 2005 | 01:33 PM
slayerreigninblood's Avatar
Default HELP--Bomb. RALLY acceleration problem
My 2003 rally ran great for two years. Now after running for 30 minutes or so, it still runs great in flat areas, but has NO POWER and no acceleration going up any type of incline/hill. Push the throttle and basically--nothing--when going up hills..just a slow crawl which obviously sux. My buddy checked/cleaned the carb, clutch,radiator and air filter and it ran great for one day then back to the crawl on hills the next day. Any advice would be appreciated..
Old Sep 14, 2005 | 03:08 PM
222's Avatar
222
check the rubber intake- several were installed incorrectly at the factory and eventually squeeze off of the head. Once it happens, they wont stay on for long ever again.
222
Old Sep 15, 2005 | 04:36 PM
thanks..after checking it appears that the intake is ok...any other suggestions
Old Sep 15, 2005 | 09:32 PM
222's Avatar
222
well, if cleaning the carb helped it to run great for a day, it may be plugged off again. Possible fuel tank contamination. This time clean out the fuel tank and fuel petcock and fuel lines when you clean the carb again.
Hope it helps
222
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
95wolv
Jul 17, 2015 08:13 PM
