Aftermarket CDI compatability? 2003
Looking at replacing my stock CDI and some of the ones I'm looking at online are either stock photos or I have some mods to perform. I'm hoping that someone has the answer that has run into this particular problem.
On my 03 the CDI has one plug on top. there is another plug mounted using the rear CDI mounting bolt. Now the problem, the ones I'm looking at seem to have two plugs on top of the CDI, and they state that they are for the 03, but the plug I'm refering to that is mounted rearward doesn't seem like it will reach the additional plug shown in the pics I'm seeing. What is that plug that's not really part of the CDI on stock, and have you had to modify the stock cable to reach the AM CDI, if in fact it does go there?
Hope this makes sense and conjurs up some answers...
Thanks guys.
Thanks guys.
So does anyone know what the second plug is that is mounted along with the CDI utilizing it's rear bolt.
Reasoning is that my CDI has one plug, some have two, and I'm curious as to if this additional plug is the same and just incorporated into the newer CDI boxes, or if it serves some purpose altogether different.
Thanks guys
Thanks guys
I have a 2003 Baja, there is only one plug on the DS CDI. there may have been something else using that bolt for mounting, but it is not part fo the CDI. I'd suggest buying the Vortex CDI with the newer plug style and be done with it. The Vortex is a quality unit with no known issues, it works, doesn't have a spoken of failure rate and is reprogramable if you ever need to do something 'more' with it. What more could you need? It isn't the cheapest on the market, but the DS wasn't the cheapest either. If we all wanted cheap we would all ride Kawasaki Mojave 250s - those things sell for like $3500-ish new.
Impalaman
1) Engine problems..
12
11-08-2015 07:17 AM
