battery not recharging
Ok when i run the bike the battery does not recharge. I tested it with a volt meter and it decreases stedaily. I just replaced the reglator/rectifer and it ran fine for a day with a new battery. So i need to know what things should i check for to see exactly where the problem could be. Thanks in advance.
what reg/rec did you get and was it new or used....
check grounds sounds to me you still have a reg problem |
