need more top end power
Old 11-26-2005, 11:16 AM
650VIPER's Avatar
Default need more top end power
At 4200', at the hottest part of summer, stock carb with an end cap runs a 162.5-167. Your lean on the top. Try going back to the stock 165 and see before you do anything else. Might just give you what you need.
Old 11-26-2005, 11:50 PM
MAXBOMER's Avatar
i think i got taller tires, his tires are worn. i think ill go with the 165jet and wait untill the biggun cdi gets here and see how it works i think the cdi will leanit more i guess will see.
Old 11-27-2005, 12:06 AM
DuneRider650's Avatar
I ride a little here and there......
im at 2800 feet above sea level and run a 177.5 main with a yoshi full exhaust and k and n...runs really amazing and pulls all the way to the top at 78mph. Why are you guys running such small jets?
Old 11-27-2005, 12:17 AM
MAXBOMER's Avatar
mostly because my plugs are a nice brown color but i will try goin a little higher, i am goin to texas next month so i really will need more fuel at 700 feet
  #15
Old 11-27-2005, 01:32 AM
650VIPER's Avatar
The higher the altitude the less air mass = less fuel to keep a correct mixture.
  #16
Old 11-27-2005, 03:12 AM
At 4 thousand feet i ran my modified stock endcap and uni filter with stock jetting and it ran good (165 main) was a little rich on the bottom so i leaned out the clip position and it ran great.
  #17
Old 11-27-2005, 09:31 AM
650VIPER's Avatar
Well there you go, you answered your own question.
  #18
Old 11-27-2005, 11:09 AM
propolaris's Avatar
Man, I have a 200 main in my DS. It wont run good with any thing smaller. Maxbomber i sent my fly wheel to rath racing and had it lightened. If you do that you will out run your brother bad. And put a cdi box on it.
  #19
Old 11-27-2005, 04:08 PM
200 main at what elevation and with airbox lid on or off?
MeadowlarkFarm
11-27-2019 08:40 PM
salixair
11-03-2015 08:25 AM
scorpiankill
09-10-2015 09:14 PM
MeadowlarkFarm
09-09-2015 03:08 AM
byronman
09-06-2015 06:34 PM
Quick Reply: need more top end power
