ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   CAN-AM (BRP) (https://atvconnection.com/forums/can-am-brp/)
-   -   Sprag Clutch change..now won't start?? (https://atvconnection.com/forums/can-am-brp/228264-sprag-clutch-change-now-wont-start.html)
Dingo2 Jan 20, 2006 12:24 AM
I just changed out my sprag clutch tonight..put everything back together, but now it won't fire. I know when the battery is alittle low, somethimes they don't start..its on the charger right now. Is there anything I could have done when putting her back together that would cause it to not fire. The starter turns over the motor, but it just won't fire. Carb settings should be ok..it was starting great 2-3 weeks ago..except for the sprag noise...Any ideas..am I missing the obvious??[img]i/expressions/face-icon-small-confused.gif[/img]
Hightower Jan 20, 2006 12:30 AM
if it can turn the starter its got enough juice to run...I've pushes started my bike before and ran fine after running down the battery leaving the lights on.
the trigger coil that signals the cdi is under there where you were working, if you are certain there is no spark this would be my first guess.
R00ST Jan 20, 2006 12:35 AM
I take it its actually turning the engine over? If it isnt (but sounds like it is) you probably put the washer on the wrong shaft. When I did mine I accidentally put a washer on the upper gear post shaft, and it was supposed to be on the lower (i think) so when I tightened it up, it put pressure on the gear and didnt let the starter crank it.
Mrneg9 Jan 20, 2006 12:41 AM
If the bike turns over you probably put it back correctly. Thats funny because when I replaced my sprag clutch I had the same problem. It would not start. I couldnt figure it out at first. It ended up I had to charge the battery. That was all the problem. I hope its the same out come for you. Later, D
Dingo2 Jan 20, 2006 09:08 AM
Yeah, the bike turns over so I'm pretty sure it was put together correct. After all night on the charger, it still won't fire this morning..haven't checked for spark yet.
Hightower, if there is no spark, you think it could be the trigger coil...? What about the cdi. I'm back to the stock cdi, but I do have a aftermarket (Pro-Comm) I think that I could try.
Dingo2 Jan 23, 2006 09:45 PM
Update..well sorta..
We pulled the outside plug wire, put in a new spark plug and I am getting spark. Went ahead and changed both plugs, hoping that this might be all it was..still no start??
One thing I do remember as we were putting the flywheel back on..when I was lining up the grove with the flywheel key, it was alittle tough to get seated and the key was loose. I'm pretty sure the key is supposed to be loose, but what if somehow the key popped out or is out of position. My guess is that if the key wasn't in there, the starter won't even turn the motor over..Any Suggestions..
Could it be a bad CDI or trigger coil as Hightower mentioned..how do I check any other electrical stuff...Keep in mind, all was running great before I made this repair
Help..anyone!!!
PS..carb is getting fuel..air filter just cleaned.
Dingo2 Jan 24, 2006 07:05 AM
Anyone?? b
THEBOM Jan 24, 2006 10:38 AM
When you pulled the starter sprag, did you pull the whole flywheel and hub apart?? if so your probably out of time on the pick up. With the piston at top dead center the pick up should be just past the pick up. I belive to the front side of the bike.
Hightower Jan 24, 2006 11:08 AM
I agree, if the bike ran fine prior to taking apart, then the problem is most likely in the area you worked on, rather than the CDI. since you are getting spark on your plugs as you visually confirmed, then the trigger coil was most likely not damaged during your work, so I would guess timing as THEBOM suggests.
BigWaynester Jan 24, 2006 02:24 PM
THEBOM beat me to it, I was going to suggest the same thing, it sounds like you are getting spark just at the wrong time. It is an easy mistake to make if you don't mark everything when you take it apart.
© 2026 MH Sub I, LLC dba Internet Brands
