It seems all of the power is high end?
Old May 11, 2006 | 05:11 PM
FatHolly's Avatar
Default It seems all of the power is high end?
Ah, man... you definetly need an exhaust. HMF is what I run... Love it!..$230 shipped. The ODP End Cap is probably same or better performer, and $75 or $80 cheaper including jets. Get a K&N also, about $50. You'll be stoked.
Old May 11, 2006 | 05:20 PM
Coyoteman's Avatar
Just gear it down, a 14 tooth front sprocket with those 22's and you should be able to wheelie no problem.
Old May 11, 2006 | 05:32 PM
savagebeating's Avatar
what is the stock front sprocket on the ds?
Old May 12, 2006 | 05:15 PM
DuneRider650's Avatar
I ride a little here and there......
Stock front is 16....i had the same problem as you....you picked a bad sport quad tire. That tire is about 10 pounds heavier prob more than those stockers then you also have the extra gearng because they are larger....gear down to a 15 on the front and go up 1 or 2 on the rear and it will be CLOSE to stock but still not as good. I went to mudlites which are about 17 pounds in 22 inch if i remember right while the stockers are 12 or something and bearclaws are in the 26 pound range and noticed a fairly good difference in power...Pipe, jet, filter, sprocket change and you should be set.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Nondem
Feb 22, 2020 12:20 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
Chocobamofo
Jul 10, 2015 07:46 PM
