ds650 jetting 195 main??..
Old Feb 23, 2009 | 01:14 PM
toydoctor's Avatar
Default ds650 jetting 195 main??..
just re-jetted my 04 bajax...i pulled the airbox and put k&n on...also running rwr full race exsaust
im at 800 ft in oregon
i changed the jetting from a 185 main with clip on 2nd notch due to the airbox and bigger pipe (was running alba and airbox)
the instructions said to install a 195 main..with clip on third notch and turn the air mix screw out 2 1/4 turns...the brass screw was siezed and i couldnt get it to budge....also ended up stripping it...
it was currently stuck at 2 turns for the 185 jet
i put it all back together and test ran it around the block...everything seems to be allright?...whatcha think?...is 2 turns close enough???
Old Feb 23, 2009 | 02:08 PM
DragonDJ11's Avatar
That will be fine. That 1/4 turn should be ok
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Brandon400
Sep 5, 2015 08:44 PM
