i bought a 2009 can am 650 max outlander and i wont start
i bough a 2009 can am 650 max outlander and we started it when we got it home then wee shut it off and we tried to start it and it only hums which is the fuel pump and when we hit th start button and it ticks and fuel pump hums and the gauge say check engine and a guy told me the secuity sytem kicked on when it wasnt saposed to since it has a d.e.s.s. system which is a security system and he doesnt know how to turn it off so can any one give me and tips or ways to fix it or get it started im kinda desperate.
Brand new? Make sure you are using the right key and that the kill switch is on. Other than that, it's back to the dealer.
Is it in Park or Neutral?
Is the brake pedal pressed down when you are trying to start it? |
on the handle bars or on the floor
If you are in park or neutral you SHOULD not need to apply the brakes. But you can use either the hand or foot, but make sure your brake light is turning on when you apply them. Seen some brake switches go bad.
Definitely check to make sure your kill switch is in the run position. Red switch on the left handle. Another possibility is the starter got "stuck". If you can, try tapping the side of the starter with the handle of a screw driver. |
no cuz i hook p a jump starter to the starter cable and it turned just fine i sounded like it wanted to start but it is in security mode so im going to get the cpu reset in norfolk ne
So it worked fine when you left the dealer, trailered it home, and now it won't start after checking everything is in the run position. I am willing to bet a electrical connection was not fully locked into place and it came loose, or possibility a fuse went out.
Good luck. |
Try putting the key in 180 degrees to what it is now, if you haven't already. Also could be the chip under the key rubber bad??
If it's a 2009 load it up and take it back
Yep, it would be at the dealers if it was me...
