2006 ds 650x starting problem
Old 05-21-2009, 07:41 AM
haazydozzy's Avatar
Default 2006 ds 650x starting problem
My ds would start normally, after a while it got harder an harder to get the motor too run with electric, i now have to drag it behind another machine to start, there is no problem then, turning the motor over with the electric start does not work period. when i drag it to start, after a couple minutes of running it will start no problem with the electric start, i have checked all fuel/air lines for leaks, bought a carb kit, i am stumped an the mechs at the dealers cant figure it out either, please help,
Old 05-21-2009, 08:34 AM
yellowdemon23's Avatar
Sounds like your valves are too tight. After running the motor the engine heats up as well as the valves allowing the starter to be able to turn the motor over. Adjust your valves.
Old 05-21-2009, 09:19 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Tight valves!
Old 05-21-2009, 09:44 AM
justme23005's Avatar
Do a compression test. then drag it & get it started.... run it until it is up to temperature, then do another compression test.. The second test will probably be higher than the first... if it is, adjust your valves...
if they are both low, pull it apart & look at the rings..
Old 05-30-2009, 07:43 AM
haazydozzy's Avatar
the starter turns the motor over, compression test ran the same numbers hot and cold,
lol im stumped
Old 05-30-2009, 09:51 PM
how much compression did it have?
BillinIll
06-19-2015 01:39 PM
generalpops
06-05-2015 08:23 PM
garyt1975
06-05-2015 08:53 AM
generalpops
06-03-2015 08:25 PM
1000gade
05-27-2015 12:37 PM
Quick Reply: 2006 ds 650x starting problem
