No Crank
Well I’m that guy needing some help. I have a Ds650 that will not crank. I have a solid battery but if I hit the start button sends voltage to the solenoid that has 12 volts but here is the catch. 12v sitting on one side of the start button but once I hit the button only sends like 3v to the solenoid and the same to the starter. Not sure if I could have a bad ground issue or a bad button issue please help.
