Is it ok to upshift w/o using the clutch??
You cannot upshift a DS without using the clutch. You can downshift with no clutch, as long as you're not under load. If you upshift a DS with no clutch, you will be replacing the shift forks - this is what breaks. I grew up on Hondas - you can upshift all you want with no clutch, but not a DS. The transmission is not built the same - don't do it - or you will lose the forks.
cdstang
08-31-2015 07:52 AM
