Breather line overflow
im not sure if this is a problem but the inlet fitting are in the middle of the can so when the oil enters the breather/overflow it will settle in the can and not go back into the motor, that what it looks like to me i might be wrong, they both look like that have a drain on them to drain the oil out after it has the oil has gotten in it. thas the problem i see, no way for the oil to get back into the motor
Finally, enough riding time to give my opinion on the mini from Jaz.
Looks good with a chrome breather.
I did manage to have a LITTLE bit of leakage from the filter but MUCH less than anything else I've tried.
It was mounted on a slight angle but have since found a way to put it straight up.
This may work even better.
Overall, for guys that are having a lot of blow by like I have, I give it a thumbs up.
I'm just a little confused as to why it would come out the filter when the can wasn't full.
#15
Glad to hear it's working for you.[img]i/expressions/face-icon-small-smile.gif[/img] Mounting it straight up will help. Also limiting (if possible) air flow across the filter would help. Air flow across the filter creates a draw much like a chiminey, pulling more oil vapor out before it has a chance to settle to a liquid form. I am curious as to how you routed the hose to the can. I would recommend that you use gravity to help you. You might try running the hose up the radiator support to the top rail of the frame and then back to the can so that most of the oil can flow back to the crankcase and only vapor can make it to the can. Just a suggestion, this has worked for my DS.
#17
Originally posted by: Eaglecollector
Hey Al, did you figure out why the oil in the catch can looked milky. I know your engine oil was fine. But why was the catch can oil that way?
Ken, right now I run the line up the radiator and then to the back. It's actually mounted in one of the holes that the airbox was attached to.
I will try to find a way to limit the air across the filter. I can probably have a piece of aluminum made to go around the filter. Or at least in front of it.
Thanks Al
As soon as I get the Pig cleaned up I will post a picture somewhere.
#19
Originally posted by: Ward660R
How big is it? I saw it was 3" diameter but how long is it? Is the filter servicable?
Thanks
Thanks
The filter is removeable for cleaning.
#20
jrooker6
04-23-2016 07:36 PM
