Alky kit for the lectron
Originally posted by: dsmike
snake hunt is were you give it everything you got and some. LOL
we might have a drag chassis made just fo rthat weekend. kinda $$$$ but the frame with steering steem A arm and shocks weighs 31LBS. got to love that.
DAMN!! steve 31 lbs!!!
I would guess the stock frame(without andthing on it) would go about 75lbs.
Snake hunt is going to be COOL!!! this year.
Biggerisbetter.
your right the stock frame is right around 75 pounds. this frame would only need a swingam motor and plastic. motor moved forward, the front +4. so you can keep your weight back over the tires and it will stay down.
wonder if this will be legal for 4SW's? doesn't matter will NOT enter classes there anyways.
#15
hey guys im running the dual 40mm lectrons on my 733 and there is no problems delivering the fuel i need in fact im haveing a problem being a little rich and im only running 2-0 needle. I just got the bike off of the dyno on fri and the torque curve was awsome all the way from bottom to top, and theres alot of room for improvement with jetting. Ive only got a 20 power jet in and its still a little fat on top, so i dont think youll need the dual power jet set up. As soon as i get the jetting nailed ill probablly go alky, that way ill have a better idea where to start with the alky! These carbs im running now where originally set up on alky from fast by gast and theres only one power jet but they did have the adjustable power jet.
#16
#18
#19
