Help with air screw
Old May 7, 2003 | 11:53 PM
MrMeaner's Avatar
Default Help with air screw
A friend of mine has a 01 DS. It has a slipon,K&N,CDI and a RWR 42flatslide. I you are cruising at a slow speed and gas it hard it stumbles and then takes off. I cant seem to get the airscrew to make a difference. Anyone have an idea on where to start. He has a 140 main and a 42.5 pilot. I jetted down and no change. HELP
Old May 8, 2003 | 01:32 AM
biggerisbetter's Avatar
Try rising the needle up. It sounds like he may be lean in that rpm range . The needle is for "fine tuning" the "power band".
Bigger.
Old May 8, 2003 | 01:58 PM
trentk's Avatar
biggerisbetter is right. the main jet only effects the higher rpm's. the needle jet controls the low end grunt. like he said raise it up a spacer and see how she does. dont forget your allen head screws. you will strip the factory ones.
Old May 10, 2003 | 06:32 PM
TyreSpinner's Avatar
MrMeaner,
I'm having the exact same problem with mine. I have a RWR Stage 1 (with HSR 42 or 45??) I still don't know...A few people looked at the pics of it and said it was a 42, others said 45...I bought mine used with the all the mods already on it. I have a K&N filter in the stock airbox with lid on.
When u tramp it, there is a hesitation and then it flies. But that hesitation is making it hard to wheelie, etc..
I messed around with my air screw, found little results. I don't know what jets I'm using either..gonna open it up tomorrow i think. When I putter around on 2nd or 3rd at medium-high RPMs, often, If i was to release the gas to stop or slow down...it sputters, chokes and dies...
Thanks
Old May 11, 2003 | 07:56 PM
trentk's Avatar
yep... both sounds like needle jet to me.
Old May 12, 2003 | 07:51 PM
01DS's Avatar
Tyerspinner-
i had the exact same problem. Make sure all ofthe carbs breather hoses are all clear. Mine hit the pipe and melted shut, when i cut it open and re-routed it it worked fine, but the hesitation is still there. The only way to get ride of that is with an excelerator pump.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
