Hi all! New here and some Q's
4 Attachment(s)
Hi all, just picked a new bike for the kids. I got it for $100, it cranks but no spark. I've checked the cdi and it's a DC unit not AC, I've checked the trigger wire and I'm getting vAC but my coil wire out of the cdi is only like .456 volts AC.. so I ordered 2 new DC cdi and a coil.. anyway here it is
Attachment 13270 Attachment 13271 Attachment 13272 Attachment 13273 |
Nice $100 score! Get a new spark plug too. Sometimes the plug wire and cap go bad if your new CDI's don't work.
Welcome to the forums. :)
Originally Posted by MPDano
(Post 3312061)
Originally Posted by scootergptx
(Post 3312062)
Originally Posted by d-day1985
(Post 3312070)
Thanks, haven't pulled the plug yet. Are you guys using an ngk?
Fixed! I have spark. The bike runs, I have to use starting fluid because the PO took the carb a part because of the no start and must have put the slide in backwards because it doesn't move at all.. anyway I'll post up after that's squared away, other than that I'm actually surprised it started and ran decently
(Post 3312398)
I'd bet the slide is in correct. If the slide was in backwards, it'd be revving very high and you would shut it off immediatly. |
Originally Posted by LT80
(Post 3312410)
I read nothing about cleaning the carb. Your jets are prolly plugged and the choke circiut needing cleaned out.
| All times are GMT -5. The time now is 09:34 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
