What is Best Brand of Battery
In any case, I'm suspect of the charging system. I don't know much about how the charging system works on the TaoTao. Any tips for diagnosing the charging system?
Thanks!
#15
We sell both types of battery. Honda and Suzuki use gell cell, but Yamahas and Kawasakis, the older ones anyway, still use liquid acid. In both cases the liquid you pour in is sulphuric acid and in both cases we don't fill 'em with it 'til we sell 'em. It is the liquid type we are more likely to let the customer fill at home, as a full one, tipped over in the back of your Range Rover, is going to make a mess.
Regarding the original question, Check you are getting 12V POWER to the regulator from the battery, not volts, so you need a fairly high wattage test lamp. With engine off, if it doesn't glow with the same power at the reg as across the battery, you have a bad earth or bad live from battery to regulator.
#16
Instead of checking "glow" of a test lamp, would it be better to check resistance between the regulator and the battery? That is, I would expect zero ohms if the circuitry was in good shape, correct?
#17
Its most likely your stator. A stator or Magneto Coil as some call it acts similar to an alternator on a car.
There are a lot of good youtube videos on how to test your stator. Here one
There are lost of different models of stators with different wire options.
Here are some stators to take a look at. Stators
#18
OK, it is possible to be stator, but checking battery power to reg first is easy and cheap. It is also far more likely to be the regulator than either, but you can test the wires and stator, the reg you can only substitute. Maybe it is because I have found the ohms scale on all AVO meters to be inaccurate, but I prefer the test lamp to a meter for the power to regulator test.
#19
#20
Stators on quads do many things. Some are, like car stators, just providing power to the battery, but they also have a trigger coil, (usually outboard of the flywheel) which sends a timing signal to the CDI telling it when to spark. On most AC ignition systems there is also an "exciter" coil, next to the charging coils, this is there to provide the power for the spark.
Yes your picture is of a voltage regulator. If it is four wire, two to stator (usually yellow) and two to battery (usually green = earth, and red = live). If you get full power there, and the stator tests in the video show an OK stator, it has got to be a regulator fault.
