TaoTao 125 cc atv replaced carb and now no spark or start
i am puzzled as i replaced the carb on this two different atv’s and now both of them will not start. So i checked to verify spark and it seemes i am getting no spark. These atv’s started prior to carb replacement. Is there something that perhaps i didnt hook up correctly? Or is there something that i screwed up when i pulled the old carb? |
It would seem that you have knocked a wire or something when working on the carb, could be coincidence. One common thing is to knock the kill switch when working on a bike, so check that, if you haven't already.
yep your going to have to go through every connection and make sure everything is plugged in. Check for pins getting pushed out of the plugs as well
