Shuangjian 250 road legal quad where to find parts?
Ow and i do have a bit of play in the left lower arm (i know that is bad but again can't find the same arm and the spindle are not the same anyway)
I got it, the silver stub axle is from a different make, you need a stub axle to match the red one. You could get lucky with the Chinese parts suppliers, note the webs on the casting and multiple sharp steps on the red stub axle, but it is hard work looking through all those stub axles, I had the same problem on a Honlei, nobody seems to stock stub axles for that either.
Finding that part is impossible .. And i don't feel like buying lower control arm of a bashan + axle stubs. That ia like 130€ spend... But i dont see a other option .
#15
Btw i ordered 2 spindle of aliexpress cause my last crash broke my original one also i bent the part that holds the steering thing on the spindle. But what im looking for now is the silent bloc for the lower arm (cause one moves front to back its slides on its own) i know you can buy the silent bloc but don't know where. (cause again i don't wanna buy 2 new lower arms that are 37€ a piece.) . If i can get 2 silent bloc for less then 5€ and fix the moving arm. I mean i have 2 weeks to wait anyway so i got time to find things.
Sorry for my wierd words, its a mess between people helping me in French saying the items in French that i don't know in English (not that mécanic I try my best)
#17
I hadn't noticed, the top ball joint is adjustable for camber, so you should be able to alter it to make the same camber on the "silver" side. This is a bit of a specialist job. Some garages can set it using special gauges, similar to track rod adjusting equipment, which you also should get set to suit. Can't guarantee this would work 100% as castor angles could also be different, but I think not.
#18
The lower paet of the wheel is more in, and top is more out. That is positive camber lel... So can't fix that but i need euh silent bloc (what ever u call that in English) for my lower arm, its moves on its one front to back.
#20
Here in the UK there are engineers merchants, who stock bearings, chains, belts and bushes for use by people who maintain machinery. Most big towns have one or more of these suppliers, and they can get all available bushes, though they can be expensive, and the type with metal outer parts that press into the A arm, can be difficult to remove.
