Coolster 110cc cant get no power from battery
I charged my battey and hooked it up and bought new ignition and i still am not getting power no where on my atv not even lights i checked the main fuse on positive wire and its good what can i do to fix this i have a connector in the front its a female 3 prong connector and has nothing to plug to can some one plese help me
Positive is fed from the battery through the fuse to the ignition switch, so check that you have power to the lead coming from the fuse at the ignition switch. Next, check power is going to the light switch when ignition switch is on, if you get power to ignition switch, but not from it, you have bought the wrong ignition switch, or wired it wrong, or there is a break in that wire between switches.
