How good are ohlins
Old Dec 21, 1999 | 10:23 AM
oz_400ex's Avatar
I am planning on buying suspension for my 400ex.I was wondering how ohlins compare to TCS or PEP.No one here in Western Austalia has much info on atv suspension.Any feed back would be appretiated. Brett
Old Dec 21, 1999 | 07:12 PM
Blaster668's Avatar
I believe that the TCS are the best. The Ohlins are way outdated compared to TCS and PEP ZPS shocks because they still use the preload system. The TCS shocks are equal to the PEPs in performance but are a lot cheaper.
Garrett Lowman; CT240 Blaster, YZ490
Old Dec 21, 1999 | 07:34 PM
JD250R's Avatar
I agree with blaster about the TCS shocks being the best, I love mine. But, I also have ohlins and they are great if you want to run pre-load. I personally like preload on the shocks because it helps you get more air off jumps. No preload lowers the center of gravity of the bike for turns. It basically what you like: preload or no preload.
Old Dec 21, 1999 | 09:22 PM
oz_400ex's Avatar
Do i need to run front and back suspension or can i just run the fronts.How does it affect the bike by having no pre-load on the front and pre-load on the back (through woops and jumping )
Old Dec 21, 1999 | 10:28 PM
JD250R's Avatar
If you go with no-preload on the front you either need to get a no-preload rear shock or have your stock rear shock reworked to a no-preload.
Nondem
Feb 22, 2020 12:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
cornermike
Jul 8, 2015 11:44 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
