ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Drivetrain, Suspension & Tires (https://atvconnection.com/forums/drivetrain-suspension-tires/)
-   -   Who's the EZGo Hotrod Guru? (https://atvconnection.com/forums/drivetrain-suspension-tires/265387-whos-ezgo-hotrod-guru.html)
smokinhydes1 Apr 24, 2007 10:52 AM
I have an EZGo I bought 8 years ago & put a lift on it with ATV tires. My son ran over a bungee cord and it snatched ALL the wiring out! So I guess it's time for the snowmobile engine swap. Who can help me with deciding which mill and the tech info? Wiring diagrams? Sources? Thanks for any and all help!!
cluby Apr 25, 2007 01:14 AM
ok what year is it and which way does the motor and pulleys sit in it.
I took a 94 with a 4 stroke gas motor and put in a ski doo 600 it hade 22" gators lifted. Not real fast but was fun to build.
I want to do another one just got to get the cart.
smokinhydes1 Apr 25, 2007 07:39 AM
I'm not real sure of the year, when this happened I went to a local golf cart dealer to look at similar ones. The wiring was different in a 94 he had, and I couldn't find the serial number on mine....his had a plate inside the driver's glove so I came back home and looked there on mine-no plate. Uh oh. I bought it at a yard sale but I paid good money so I didn't think it could be stolen. Either way, the pulleys are on the driver's side and the junction box is mounted up high, not low like the others I saw. Any idea?
cluby Apr 25, 2007 09:25 AM
so then does yours have a 2 stroke in it or the fourstroke? Sounds like the same set up I hade. I hade to do quite a bit of moding to make mine work cause the motor I used the carbs where mounted so low.
Then the question is are you looken for a liquid cooled motor or a air cooled. Easist to get one with electric start.
© 2026 MH Sub I, LLC dba Internet Brands
