Gators or Bearclaw tires which ones are better?
IN THE RESPONSE TO THE HANDLING CORNERS AND SHARP
TURNS A FLAT TIRE AS APPOSED TO A ROUND TIRE WILL HANDLE CORNERS
AND TURNS MUCH BETTER THAN ROUND TIRES.(FLAT ACROSS THE TREAD)
REQUIRES LESS LEANING IN TURNS AND DOES NOT PULL LEFT OR RIGHT.
AND WON'T ROLL UNDER IN SHARP TURNS. I CHANGED FROM DUNLOP TO
GATORS AND FOUND THIS TO BE TRUE.
09-30-2015 01:37 AM
