2006 Polaris sportsman 500 efi electrical problem
Old 06-20-2016, 08:02 AM
bwalker2's Avatar
Default 2006 Polaris sportsman 500 efi electrical problem
when we turn on the key the pod sometimes does not display anything, and then goes blank when we try and turn it over. what could be the issue, and which module would I replace and aren't these atvs on a recall we have about 300 hours
Old 06-20-2016, 08:38 AM
Carb models were on the ecm recall not efi models. Check the battery connections first,load test it if any doubt on it's condition. If that's ok then the pdm module did have problems on some efi machines,plus it's been updated which usually means something.Item #11.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old 06-20-2016, 09:05 AM
bwalker2's Avatar
is there another module on this four wheeler
Old 06-20-2016, 12:21 PM
Yes the pdm module that I posted a link to above..Item#11.
Old 06-21-2016, 03:18 AM
bwalker2's Avatar
is there two modules on there and I know there is one under the handlebar headlight just wondering
Old 06-21-2016, 04:51 AM
Top one is the ecu or brain box as it's been called. Pdm module by the radiator has all the circuit breaker,controls charging,fan operation,etc and has been known to fail same as the ecm module on the carb models.
JonesE
Polls
04-10-2016 04:23 PM
hawkdude
19
04-04-2016 07:38 AM
abillman
03-30-2016 02:48 AM
gentlejax
1) Engine problems..
03-27-2016 10:33 AM
Leavitt Woodland
03-24-2016 02:55 AM
Quick Reply: 2006 Polaris sportsman 500 efi electrical problem
