Polaris swap.
i am wanting to build up my scrambler, wanna change my tranny around, previous owner did not take care of it, and ran it without trans fluid for a few days then decides to tell me after I purchased it. what do people usually swap these trans out with, and should I stay 4 stroke or go 2 stroke, I have super great acceleration but my top speed it bullsh^t and Can I just slip in a new ignition cause mines garbage. Thanks to anyone who can help me with answers. I appreciate it sorry for so much questions lately but I am new to this and am really into getting good at finding the problem myself without needing answers til then I'll ask you. It is a 2001 scrambler 500 2x4
Last edited by Ascrambler2me; May 12, 2017 at 08:06 AM. Reason: Forgot information
These models share the same gear case your 2001 model. You could keep a look out on ebay for a used one.
Usage : 1341306
Year Product Model Assembly
2005 ATV TRAIL BOSS 330 GEARCASE - A05CA32AA/AB/AC/FA (4994739473C03)
2005 ATV TRAIL BOSS 330 QUADRICYCLE GEARCASE - A05CA32EA (4994739473C03)
2003 ATV TRAIL BOSS 330 GEARCASE - A03CA32AA (4975037503C03)
2002 ATV SCRAMBLER 500 2X4 GEARCASE - A02BA50AA/AB (4969976997C07)
2002 ATV TRAIL BOSS GEARCASE - A02CA32AA/AB (4969816981C03)
2001 ATV TRAIL BOSS GEARCASE - A01AA32AA (4963816381C007)
2001 ATV TRAIL BOSS 325 SE GEARCASE - A01AA32AA (4963816381C007)
2001 ATV SCRAMBLER 500 2X4 GEARCASE - A01BA50AA (4963716371C009)
2000 ATV TRAIL BOSS GEARCASE - A00AA32AA (4949914991C007)
2000 ATV TRAIL BOSS GEARCASE - A00AA32AB (4960076007C007)
You might consider graphics as it's cheaper than replacing all the plastic.Polaris Scrambler Graphics - Over 80 Designs to Choose From
Ignition? If you're talking just about the switch you can find them at most online sources such as Partzilla,Cheap Cycle Parts or even one on ebay for 7 bucks. IGNITION KEY SWITCH FITS POLARIS SCRAMBLER 500 2x4 4x4 2000 2001 ATV NEW | eBay
Usage : 1341306
Looks somewhat related to a 1996 Sportsman 400 l 2 stroke that I had. I could get almost all the parts from the dealer, but check eBay first. Unless you are positive the transmission is toast, why not fill it, run a couple miles, then drain an refill and try it. Even if the idiot ran it some, there was probably enough lube left to protect it. If that bike is a 2 stroke, clean out the muffler, mine was almost completely packed with soot. Run injection oil in the injection system, not conventional premix 2 stroke oil. The front rear swing arm bushings in mine were junk plastic. I had new ones made out of bronze, then it handled nicely. You might check with AAEN , I think is the company, they had lots of racing parts.
