Weird things going on with my trail boss
Hi all, I'm having issues with my 92 trail boss 250 that have me puzzled. I started it after sitting a few weeks just to spray a few weeds with it, it felt like the brake was grabbing, the rear mechanical (the front and rear hydraulics aren't hooked up). I parked it until a few days later when I had time to mess with it, yep felt like grabbing again. I rode it around the side of the house to load onto a trailer and the brake seemed to completely seize up and the quad wouldn't move. I gave some gas and something started smoking, but didn't smell like brakes (couldn't tell for sure where the source was) and the quad died. I pulled the caliper off but forgot to shut off the gas and fuel came out the carb. Quad wouldn't start (figured it flooded, so I'd wait). Three days later and no dice, still won't start.just runs the battery down. Plug looks good, not wet, and getting alot of spark...getting fuel and air. Could I have seized something else? Like smoked the clutch or seized the crank or something? What do I need to look at?
Can you manually turn the engine over? At least that would tell you if the engine was seized. If fuel is coming out of the carb your float/needle valve is stuck open. If engine turns over than look into drive train, clutches etc.
Bottom of the crank case is a 10mm drain plug.Drain it and see if you can start it then by holding the throttle wide open. If it wont start and you have spark,check compression.If it's below 100psi time for a top end at least. If compression is above 100psi,you may have popped a crank seal behind the drive clutch.
Originally Posted by Kymco 450i
(Post 3371329)
(Post 3371336)
It you tested it a while back and it was 90psi,think I'd go ahead and pull the top end.Sounds like this last go round probably finished it off.
