timing a counter balance shaft
Old 10-26-2017, 07:51 AM
polaris Xpress 400l's Avatar
Default timing a counter balance shaft
Need help timing a counter balance shaft on my Express 400L.
Old 10-26-2017, 08:19 AM
Balancer has a dot on a tooth that aligns with the dot on the crank shaft sprocket. If gears are corroded like a lot of them from coolant that may have gotten into the cavity,bead blasting them can help you see the marks.
