ATV Winch issue
#52
I know you guys are like WTF is he thinking! I am one of those people that just has the luck of if something can crap out when I need it usually it does. I dont want to be stuck out in the woods and not be able to winch myself or someone else out if needed. I actually use my winch from time to time and its saved me a walk out a couple times.
#53
#56
You will need to cut the 2 prong connector off the new switch harness and splice the 2 wires together , the black lead will go to 12+ [ same as blue wire on old switch ] , the other 2 wires will go to the small green & black wires on the solenoid .
If the in/out is backwards reverse the small wires going to the green & black wires on the solenoid .
