MICHIGAN need riding friend/buddy over 50
#281
#282
#283
#284
If the whole top of the van was covered with solar cells it might make enough electricity to keep some batteries charged enough to run one of those little heaters that some people put under their desk. You would need an inverter too unless someone makes tiny 12 volt heaters, and I think they do.
Just put a propane heater inside and seal up the doors airtight. <--- Turning blue. Maybe I shouldn't joke about that because some people have done things like that.
#285
#286
I was thinking about a non-portable solar array fastened to the roof so it's charging at home, while driving to and from the trails, stores and restaurants, or even taking a siesta after lunch. And also an electric heater so it never has to be vented or need any maintenance other than blowing the dust out each fall. I think some of the small cubes are about 1000 watts but could be wrong. And I don't know if I can underestimate solar unless it's a lot better than it was just a few years ago. It would take a lot of the older solar panels to run an electric heater.
#288
#289
Depending on how long your going to stay a couple ( 2 ) good deep cycle batteries will last for days supplying 12v power for a couple lights, phone charger, even running the fan on a propane heater etc. I have 2 deep cycle batteries in my motorhome that can last for 2-3 days with ease running lights, water pump, fan on furnace, 12v TV, etc. We are going to convert all out interior lights to led this spring to use even less power. We spent 3 nights down south the fall before the last and had plenty of battery power with 5 people on board, we ran low on water long before the batteries went low. We only need 120v for A/C and for microwave, was to chilly for a/c but a quick start of the genny for the microwave, then shut it off after cooking was done. Don't think I would want the expense of clutter of messing with solar panels when a couple good deep cycle batteries will give you days of 12v power, along with a propane heater and even a cook stove is all you really need, they even make small portable propane water heaters if you need hot water. If not for the microwave we could go for a long time on battery power.
#290
